Hi there,
I’m trying to make a relatively simple tool in order to add profiles to a curve and set their rotations (for now). The reason I’m doing it this way is that the amount of profiles is going to alter a lot, and each needs to be manually positioned so I could really do with not needing to manually add or remove wires every time I need to add a profile, and I’m using genepools because I’ll be adding other ‘sliders’ like rotation around plane x axis and scale, which I want to stay associated with those specific profiles. Ideally I just want to be able to copy paste an existing gene pool, and just be able to tweak the values to create the relevant profiles.
My issue is that, using the Get Same Type component, it only picks up the data from the gene pools when the wire connecting to it is re-connected. Is there any way anyone knows that I can make it run ‘live’ so that it updates when any of the gene pools are altered, rather than only the one that it connects to?
I’ve attached a couple of screenshots to hopefully clarify.
Thanks!!!
Rup
