When I use ViewCapture, viewCapture.CaptureToBitmap(view), the view is “perspectiva” layout, it generated the image 1, how do I get the image 2 through API then? which was show up when I click top-left render button. Thanks a lot!
I got it working using RunScript(), but how to suppress the “Missing file window” then, Thanks!
RhinoApp.RunScript("_Render", false);
RhinoApp.RunScript("-_SaveRenderWindowAs " + path + " _Enter", false);
RhinoApp.RunScript("_CloseRenderWindow", false);
Does this work any better?
RhinoApp.RunScript("_-Render", false);
– Dale
Let me check, Thanks Dale!
Thanks Dale, I changed to use RhinoApp.RunScript("_-Render", false);, the dialog still pop-up, any API to suppress it, Thanks Dale!
Thanks Dale, I suppressed the dialog manually, it was not shown any more, any way to reset the Rhino environment, to get the dialog show again? so, I can send you the file which had the issue, Thanks Dale!
