Grasshopper can seemingly recognize “planar curves”, or at least the tool tips I’ve looked at says so.
Does that mean that there’s a node to extract the plane from a planar curve (and thus hopefully also an arc?
“Planar” component is what you need.
It will give you a boolean true/false if the curve is planar, the most fitting plane (even if not planar), and the deviation.
Thanks, this helped me years later
