Get minimum & maximum points from bounding box?
So I’ve gotten this far:
But before I try to wrangle a perhaps too complex newbie answer from these outputs, is there an easier one I’m missing?
You can use evaluate box, with u,v,w set to zero (for min) or 1 (for max)
point
Thanks for the tip!
Could you explain to me why the Y output, which seems to contain two values, becomes only seemingly the maximum value once you plug it into a number node? What if I wanted the minimum value?
simply put:deconstruct box returns the domains on x,y,z axes. (e.g. on y axis, your box starts from so and so up to so and so) if you plug this in a number it turns this domain into a number (maximum minus the minimum)
