Get material applied to an object
Hi ! I’m trying to get the material applied to an object in Rhino from grasshopper thought a Guid in python, I summited pseudocode in case anyone knows how to properly implement it, thank you.
I solved it, it was pretty easy, I upload the solution in case anyone could need it
Could you share your Code ? I get a weird error message
Managed to make the code work after playing around:
import scriptcontext as sc
import Rhino
sc.doc = Rhino.RhinoDoc.ActiveDoc
index = rs.ObjectMaterialIndex(x)
name = rs.MaterialName(index)
print(name)
out = name
