Get Index value of input
Just a silly question, how to get index value from Item Access input in c# script?
How about:
List listObj = new List();
int idx = listObj.IndexOf(obj);
or
int index = myList.FindIndex(a => a.Prop == oProp);
Cheers
I am quite new in using Data Tree, i was trying to list individual curve from an array, how do I display each curve on every curve array from DataTree<Curve> dt = new DataTree<Curve>();?
The question is if you really need DataTree. Why not using a simple List?. In your example you have a really simple (flat) DataTree. It looks more like a list.
I tried using list now, but i still can’t see the individual curves. How do i see the individual object?
List<Curve> dt = new List<Curve>();
In your first post you want to get the index. This can be done with
int idx = yourList.IndexOf(yourCurve);
In your last post you want to get the curve at index. This can be done with
var crv = yourList[i];
With DataTree should look like this:
foreach(GH_Path myPath in test.Paths)
foreach(object obj in test.Branch(path))
// here obj = your curve
Got it, Thanks
