Get faces of a surface
I like to get the differents faces to compound this surface. Exist a method to make it?
Regards.
Are you asking for surfaces that represent the isoparms of this surface?
you can split it by isoparm if you want to dissect it.
Thanks a lot @theoutside . I am trying with these steps:
  • Split
  • Isocurve
  • Select surface
  • Direction=Both
But exist a way to select automatically the isocurves?
Regards
extract isocurve- direction = both, extract all
that will get all your isocurves, select them and gumball move up a bit to make them easy to select.
run split, select your surface and then select all the iso’s you just extracted.
split will cut the surface into it’s respective sections
Thanks so much
