Get display component (Pattern Hatch) content via python code
Thanks!
I got the same result. This is the return value of rg.Hatch.CreateDisplayGeometry(n,Hp[p],1):
I don’t know where is the problem
Try to print every line until you get where is the error
downloaded and opened as expected…
Check this with c#
hatches_2.gh (10.8 KB)
Check this as well
These are two components added to Fennec addon and can retrieve data from components in the canvas.
I don’t test them for all components
data.zip (23.7 KB)
test_comp.gh (12.7 KB)
Hi, can you please check and update here about ‘geos’?
thanks
Hi @anon39580149 !
It works perfectly!!! Thank you! Really appreciate your help and your kindness!!!
Just out of curiosity regarding your question:
When you said “explode it in Grasshopper”, what did you mean by that? would you mind to add a short example for exploding PatternHatch in python?
Thanks again!
Explode hatch: deconstruct the hatch to its boundary, pattern
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Hatch_Explode.htm
And this
