Get closed boundary curves of ON_Brep
(Alexander Schiftner) #1
I tried to find out how to get the closest boundary curves (if any) of an ON_Brep object, unsuccessfully. I’m looking for a function like Rhino.DuplicateSurfaceBorder in RhinoScript. Is there a C++ SDK function doing this?
This explanation of ON_Brep is nice, but unfortunately it doesn’t show the case of polysurfaces. I guess I need to traverse the boundary edges in order to achieve what I’m looking for.
(Menno Deij - van Rijswijk) #2
This seems to work for an open BREP. As you suggest, you need to traverse the boundary edges.
NOTE I was using the Rhino SDK, not OpenNURBS. But I don’t think I was using any proprietary stuff.
const ON_Brep* b; // obtained from document or elsewhere
ON_SimpleArray<const ON_Curve*> curves;
for(int i = 0; i < b->m_L.Count(); ++i)
    const ON_BrepLoop& bl = b->m_L[i];
    // get outer loops
    if (bl.m_type == ON_BrepLoop::TYPE::outer)
        for(int i = 0; i < bl.m_ti.Count(); ++i)
            const ON_BrepTrim& t = b->m_T[bl.m_ti[i]];
            if (t.m_ei < 0)
                continue;
            // only look at boundary type trims
            if (t.m_type != ON_BrepTrim::TYPE::boundary)
                continue;
            // get the brep edge for the trim
            const ON_BrepEdge& e = b->m_E[t.m_ei];
            curves.Append(b->m_C3[e.m_c3i]);
for(int i = 0; i < curves.Count(); ++i)
    const ON_Curve* pCrv = curves[i];
    context.m_doc.AddCurveObject(*pCrv);
(Dale Fugier) #3
Here is my version:
Description:
  Duplicate the border curves of a Brep.
Parameters:
  InBreps   [in]  - The input Brep.
  OutCurves [out] - The border curves. Note carefully: memory for the curves
                    is allocated and becomes the responsibility of the caller.
Return:
  The number of curves added to the OutCurves array..
Remarks:
  In order to to duplicate the border curves of surfaces and polysurfaces,
  you need to search the object for naked edges. A naked edges is one that
  is not connect to other edges. Also, the OutCurves array will contain
  individual, unjoined curves. If you need them joined, use ON_JoinCurves.
int RhinoBrepDuplicateBorder(const ON_Brep* InBrep, ON_SimpleArray<ON_Curve*>& OutCurves)
  if (0 == InBrep)
    return 0;
  const int OutCurves_Count = OutCurves.Count();
  for (int i = 0; i < InBrep->m_E.Count(); i++)
    const ON_BrepEdge& edge = InBrep->m_E[i];
    // Find only the naked edges
    if (edge.m_ti.Count() == 1 && edge.m_c3i >= 0)
      ON_Curve* curve = edge.DuplicateCurve();
      // Make the curve direction go in the natural
      // boundary loop direction so that the curve
      // directions come out consistantly
      if (InBrep->m_T[edge.m_ti[0]].m_bRev3d)
        curve->Reverse();
      if (InBrep->m_T[edge.m_ti[0]].Face()->m_bRev)
        curve->Reverse();
      OutCurves.Append(curve);
  return OutCurves.Count() - OutCurves_Count;
(Alexander Schiftner) #4
Many thanks for your help!
