Get certain mesh points
I want to pick the outer shell points of a mesh to define P1, P2 and P3 points, shown in Figure. Is it possible to select certain points of a mesh? I have tried the bounding box component but it only gives the perfect outer shell. Since I want to measure the deviation I want to define a clear outer box like an offset of that mesh.mesh_q.gh (238.9 KB)
outermesh
This would be one way of doing it.
mesh_q_LR.gh (241.4 KB)
Thank you for your reply. Actually I want to select very end points of the mesh to find the middle point.
outermesh2
Ok, try this.
mesh_q_LR2.gh (242.5 KB)
If I read your initial question again, maybe this is more what you had in mind?
Intersecting the mesh with a plane at different hights and finding the midpoint.
mesh_q_LR3.gh (243.5 KB)
Thank you very much! It is very helpful :four_leaf_clover:
