Get Brep object
I’m stepping through all objects in the model to find a specific object named, ‘HULL’. Once I’ve found it, I need the Brep it represents, but I just can’t seem to get from the object to its geomerty.
            var rh_objects = doc.Objects.FindByFilter(settings);
            if (null == rh_objects || 0 == rh_objects.Length)
                return Result.Failure;
            foreach (var obj in rh_objects)
                if (null != obj.Attributes.Name)
                    if (obj.Attributes.Name.ToUpper() == "HULL")
                        strId = obj.Id;
                        var brep = obj.???;
                        break;
                    }//if (obj.Attributes.Name.ToUpper() == "HULL")
                }//if (null != obj.Attributes.Name)
            }//foreach (var obj in rh_objects)
obj.Geometry ?
not tested but something similar to …
     //var brep = obj.???;
     Brep myBrep = obj.Geometry as Brep;
     if (myBrep == null)
     else
         // do something with myBrep
Thx. That did it.
