I have a lot of keys from a project Im working, and I’ll like to know if there is a way to extract all the Key Names as a text.
Thank you in advance!
You could use the Metahopper plugin. Just use filtering to get rid of whatever you use as the “blank” option.
Metahopper Telepathy for Flux.gh (7.4 KB)
You could even remove the name of “blank" (literally leave it blank) then filter that way, too.
The only trick that I can see, is that if you update the number of keys, you have to disconnect and reconnect the blank one from the Metahopper components, it doesn’t seem to automatically refresh. Hm.
That’s a big question. It can do a lot, I haven’t even begun to scratch the surface of its capabilities personally.
Right now, the biggest use I have for it is keeping groups on the canvas colour-coded properly according to my template. I’ve also used it to enable/disable GH objects remotely from other toggles, automatically add titles to them, things like that.
It can be downloaded here, along with example files that will likely do a far better job of explaining than I can.
