Get all materials in scene (Python)
Hi all,
I want to list all materials in the scene, so I can select a material from a list and assign it to a selected object.
I tried the following code, to no avail:
import import rhinoscriptsyntax as rs
def getSceneMaterials():
    rdk = rs.GetPlugInObject('Renderer Development Kit')
    #get list of all RDK data ids in the document
    rdkALL = rdk.FactoryList()
    #filtered materials ID list
    matIDList = rdk.ContentList('material')
    #get materials names
    matNames = []
    for i in range(len(matIDList)):
        matNames.append(rdk.ContentInstanceName(matIDList[i]))
    for i in range(len(matNames)):
        print(matNames[i])
Hoping this question won’t be buried … :grimacing:
Are you talking about these?
you can get to those by the following:
import scriptcontext as sc
mats = sc.doc.Materials
documentation here:
https://apidocs.co/apps/rhinocommon/6.14.19118/T_Rhino_DocObjects_Tables_MaterialTable.htm
Hi Will,
Thanks for your reply!
Alas, the code shows only the used materials:
materials = scriptcontext.doc.Materials
for material in materials:
    print(material)
Returns
Material: neutral (0)
I mean all materials in the scene, even if unused:
Untitled
In the documentation I cannot find a way to show all…
Kind regards,
Dick
sc.doc.RenderMaterials seems to be the correct table you’re looking for
Indeed the RenderMaterials table is the one you want.
Just 19 hours ago I posted a snippet where you can see how I loop over all materials:
In this specific script I pick with some extra conditions, but the simplest form to create a list with all materials is:
rmats = [rm for rm in sc.doc.RenderMaterials]
My bad. Indeed it’s correct. I couldn’t find the methods right away.
Thanks guys!
When getting all materials present in the document, I’m missing material “neutral”:
What is happening?
Could you share the 3dm with these materials?
Here you go.
conversion.3dm (150.9 KB)
There is definitely something weird going on, need to investigate more.
Hallo @dick.lelyveld,
It turns out that the material is an old-style material. You need to replace it with a new material in v6.
Thanks you very much Nathan! I am much oliged.
Indeed I updated Rhino last week…
