Hi all,
playing around with rhino compute compiled with VS and running on my local mashine i was able to use compute.rhino3d.py successfully but when i try compute.rhino3d.js a error occured.
This is the simple javascript and html index
// Import libraries
import rhino3dm from 'rhino3dm'
import { RhinoCompute } from 'rhinocompute'
// Load rhino3dm
const rhino = await rhino3dm()
console.log('Loaded rhino3dm.')
// Your code ...
RhinoCompute.url = "http://localhost:5000/"
RhinoCompute.apiKey = ""
const c1 = new rhino.Circle([0,0,0],10)
const c2 = new rhino.Circle([5,0,0],10)
const curves = [c1,c2]
console.log(curves)
const ca = RhinoCompute.Curve.createBooleanUnion(curves)
console.log(ca)
<html>
<head>
<!-- stuff -->
</head>
<body>
<!-- Import maps polyfill -->
<!-- Remove this when import maps will be widely supported -->
<script async src="https://unpkg.com/es-module-shims@1.10.0/dist/es-module-shims.js"></script>
<script type="importmap">
"imports": {
"rhino3dm":"https://unpkg.com/rhino3dm@8.4.0/rhino3dm.module.min.js",
"rhinocompute": "https://www.unpkg.com/compute-rhino3d@0.13.0-beta/compute.rhino3d.module.js"
</script>
<script type="module" src="./script.js"></script>
</body>
</html>
These are the error messeages from the browser and the server consol.
Rhino 7 is in use.
Maybe someone can give a tip to solve the problem.
