Geometry Photoshoot - Batch Render Geometry to Images
Good Morning,
I’ve been asked to write a PDF with images of all the curves in a Rhino document - one curve per page.
I can handle the PDF part but how do I batch render curves to images?
I see that there are CreateMeshPreviewImages methods for meshes but not for curves.
I could zoom a view port to each curve in turn and use the ViewCapture Classes to capture an image. Is that the right approach?
But i think that would make the user dizzy - is there any way to render a curve offscreen? Can I use an offscreen View?
Finally can this be done with a headless document?
Hi @david.birch.uk,
I’ve seen others use this technique, so it seems reasonable.
No. Headless document’s are not attached to any display (pipeline).
– Dale
