seemingly simple geometry of a long closed cylinder fails to trim, split, boolean (when extruded)
Intersection returns a closed curve which still fails to trim, split, boolean (when extruded)
fail_split.3dm (566.4 KB)
Hello- for some reason the edge and vertex tolerances on the cylinder are way out of whack (What
command) - Explode
, RebuildEdges
Join
and then trim.
How was the cylinder made/edited?
Thank you Pascal! Worked out.
The cylinder was part of block which was exploded. The block was placed along a curve via grasshopper and Elefront
