Hi Guys,
Im trying to do a complex hex pattern that moves across several surfaces that are joined. I dont know where to go for help.
HEX Pattern 11-1-2018 COMPOUND SRF.gh (13.2 KB)
MULTI-SURFACE TEST 002.3dm (167.4 KB)
Hi Guys,
here is simple mapping:
However. Hexmapping usually is much more complicated. For better results forget about Lunchbox. Build a Hex pattern from curves. This will allow you to better control the outcome.
Hope this helps
Interesting. How would you get a gradient hex pattern with this approach? I have a lot to learn. is that R6?
Thanks for sharing Tom!
