Hi everybody,
is it possible to integrate the P-Set to rhino objects via GeoGym as it’s possible for parameters by using user Text ?
if yes, how taht it do ?
Thanks for your answer
Hi Samir,
Can you elaborate a little bit further on what you are trying to achieve? You can set IFC p-sets to objects in Rhino using grasshopper and GeomGym. Take a look at the attached script.
If you are importing IFC into Rhino you can select to add properties to the rhino objects user text on import.
Hope this helps a bit.
Cheers
Nathan
200326 ifc from rhino objects_mm.gh (33.8 KB)
Hi Nathan,
Thank you, i tryed to do that whitout gh3d and i didn’t find solution !
The goal was to know if it’s possible with just GG for rhino whitout gh3d to set some parameters in their P-Set which match them, for exemple x1,x2 parameters in P-setX and y1,y2 parameters in P-setY and export all to ifc
i will to explore your gh3d definition and i will come back to you for possible questions.
Thx again Nathan
Hi Nathan,
your script works well, thank you !
for confirmation, we can’t use gg Rhino and gg Grasshopper in the same time for export to IFC, is not it? for example , set IfcProject, IfcSite,IfcBuiding,IfcBuildingStorey and Ifc Classes to objects by using gg Rhino ( by the gg layers) and set parameters with their P-Set by using gg grasshopper and export to IFC ?
second question, is it possible to set parameters and their P-Set whitout using gg grasshopper ?
Thank you
Hi Samir,
It is possible. I have actually just been learning about this myself. Can you please go through these two pages on our technical website and let me know if they are of use. I will add some information on how to generate property sets from grasshopper shortly.
https://app.gitbook.com/@geometrygym/s/documentation/rhino-grasshopper/ifc/ifc-tools-for-rhino/ifc-export/rhino-to-ifc-example
Cheers
Hi Nathan,
I didn’t know the existence of Property Template File it’s seems well ! thank you . For me its not complex like method but i imagine that could be complicated for some users , that will be well if you simplify it like assigning IFC Information using ggRhinoIFC Layers !
i will do some tests and I look forward your information on how to generate property sets from grasshopper
Thx again Nathan
Cordialy,
for those looking the example of how to create a property set template, its on this page (it get my time to figure it out). @NathanGG The page “using rhino IFC layers” should point to this page (or better to the actual sample file), it would be handy for the user/reader, currently its not very clear.
Overall, GG has always suffered of a updated and complete documentation. I find this quite a important problem, given its complexity (sooo many marvelous features “hidden” here and there)
