Hello all!
I have a script which uses Ladybug and the Genome component to figure out in which positions my vertical louvers need to be positioned for optimal shading.
The script works although I have to manually connect each list item ( each vertical louver ) individually to the genome component.
My question is if there is a better or more simple way to do the same thing without having to connect everything manually?
Thank you!
