Hi
I create a component , to read image.
The first input is generic parameter , i want a solution to check if the type of the input data is a string i use Image.FromFile(input_data)
and if it is an image i leave it as it is.
pManager.AddGenericParameter("Bitmap".....
This works fine in c# component but i don’t find the right way to use it in visual studio
private void RunScript(object x, object y, ref object A)
try
Bitmap bmp = (Bitmap) Image.FromFile((string) x);
A = bmp;
catch
Bitmap bmp = x as Bitmap;
A = bmp;
I try this in visual studio but i get an error when i plug a file string to the input
1. Invalid cast: String » Bitmap
object bmp = null;
Bitmap image;
string data = "";
try
image = (Bitmap)Image.FromFile((string)bmp);
if (!DA.GetData(0, ref data)) return;
catch
image = (Bitmap)bmp;
if (!DA.GetData(0, ref image)) return;
Exceptions originating in catch
blocks will throw elsewhere. You really don’t want to do anything risky in a catch block.
Here’s how I’d write it:
Bitmap image = default;
if (value is Bitmap inputBitmap)
image = inputBitmap;
else if (value is string fileName)
image = (Bitmap)Image.FromFile(fileName);
You can either use a single try...catch
frame around all of it, or put one inside the else
block.
Thanks @DavidRutten
I tried something like that before but like now i get this error message
1. Solution exception:Object reference not set to an instance of an object.
object bmp = default; // or null the same error
if (!DA.GetData(0 ref bmp)) return;
if (bmp is Bitmap inputBitmap)
else if (bmp is string fileName)
CreateSvg(image); //code to create list of points from bitmap (object bmp >> image)
If i use Bitmap bmp
to read image or string bmp
to read image from file, this work.
A simple component, the output always null.
namespace LoadImage
public class LoadImage : GH_Component
public LoadImage()
: base("Image", "Img",
"Load image",
"Params", "Util")
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
pManager.AddGenericParameter("Image", "I", "", GH_ParamAccess.item);
pManager[0].Optional = true;
protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
/// <param name="DA">The DA object can be used to retrieve data from input parameters and
protected override void SolveInstance(IGH_DataAccess DA)
if (!DA.GetData(0, ref bmp)) return;
DA.SetData(0, image);
public override GH_Exposure Exposure => GH_Exposure.primary;
protected override System.Drawing.Bitmap Icon => null;
public override Guid ComponentGuid => new Guid("D649643A-DF36-4934-B138-037E9DD8E66A");
Have you looked at the actual type and value of bmp
in the debugger? What does it say? I’m guessing it might be GH_String or something wrapped like that.
Yes i tested with GH_String and it work
object obj = default;
if (!DA.GetData(0, ref obj)) return;
if (obj is Bitmap inputBitmap)
else if (obj is GH_String fileName)
image = (Bitmap)Image.FromFile(fileName.Value);
Update :
I still have a problem with Bitmap, the output always null
I find a solution in Aviary.Macaw.GH code
using Grasshopper.Kernel.Types;
using System;
using System.Collections.Generic;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace Aviary.Macaw.GH
public static class Extensions
public static Aviary.Wind.Mathematics.Domain ToDomain(this Rhino.Geometry.Interval input)
return new Aviary.Wind.Mathematics.Domain(input.T0, input.T1);
public static bool TryGetBitmap(this IGH_Goo goo, ref Bitmap bitmap)
This file has been truncated. show original
I add this class and use IGH_Goo instead of object
bool output = true;
if (goo.CastTo(out Bitmap bmp))
bitmap = (Bitmap)bmp.Clone();
else
if (goo.CastTo(out Image image))
bitmap = (Bitmap)image;
else
output = false;
return output;
This code work without errors:
Bitmap image;
void CheckBmp(IGH_Goo obj)
Bitmap bitmap = default;
if (obj != null)
Type dataType = obj.GetType();
if (obj.TryGetBitmap(ref bitmap))
image = bitmap;
else if (dataType == typeof(GH_String))
GH_String ghString = (GH_String)obj;
image = (Bitmap)Image.FromFile(ghString.Value);
