Salve a tutti,
mi sono imbattuto in un problema che non riesco a risolvere all’interno di uno script di GH che ho creato; cerco di spiegarlo a parole ma visionando lo script in allegato si comprenderà meglio il problema: dopo aver eliminato dei punti tramite cull index e spostandoli lungo una normale si crea un’ aureola di punti in un unico punto.
Lascio lo script in allegato, ho evidenziato i due componenti nei quali è possibile visualizzare il problema.
Vaso_01.gh (16.4 KB)
you need to filter out the normals too, otherwise the lists don’t match:
Vaso_01a.gh (13.4 KB)
Google Translate: https://translate.google.com/
Hello everyone,
I ran into a problem that I can’t solve in a GH script that I created; I try to explain it in words but by viewing the attached script you will understand the problem better: after eliminating the points using the cull index and moving them along a normal one, a halo of points is created in a single point.
I leave the script attached, I have highlighted the two components in which you can see the problem.
actually it was pretty obvious as a procedure, I don’t understand how I couldn’t think about it before; thank you so much!
