Generative site design
Congratulations!
I want to try to create a script that will generate options for the conceptual placement of buildings on the site. The number of buildings will depend on the ratio of the area of ​​the plot to the area of ​​the spot of the house as a percentage. The width of the buildings is given by the operator, and the length of the building is given by the algorithm, it can be a range of lengths beyond which the algorithm cannot go. That is, conventionally, the width of the building is 16 meters, and the length is set by the algorithm from 20 to 50 meters. Further, the distance between buildings is also set by the operator, for example 30 meters. I also plan to use Galapagos to find options for placing buildings on the site.
Are there similar solutions on the forum that solve these problems in one way or another?
Thank you
