Generating a 3d model line in Revit Using the Linked 3d string line dwg
Hi Guys,
Good day, I am wondering if someone have create a 3d model line using the linked dwg 3d string in the same space? the issue is anything that you are creating in revit is looking for the reference level that you have to host the element? what I need is to generate the 3d model line on the same space so that I can easily use it for my accurate modelling.
Kind regards,
Joel
Hi Joel,
The Revit Model Line requires a reference level/plane.
Thank you Japhy, cheers.
