Generate shell of an object - occurring artefacts
I tried to create a shell from a object. In the case that it work’s it will look like the following picture:
on the left side is the object as an entire block. And on the right side is the object as a hollowed-out block (a shell was created with the command “shell”).
Now I have tried the same for another object. The result is at the following pictures:
As you can see, there are some artefacts or defective surfaces in the upper region, where the radius is the strongest.
I also tried to create a parallel surface from the object, but the same artefacts appear.
How can I now create a shell of my object? If the artefacts on the surfaces are easy to edit, so I can correct the errors myself. But how?
Can you upload your file here so someone can take a look at it? Use the vertical arrow symbol above where you type your post.
Hi, here is the file, thank youshell.3dm (5.0 MB)
You need to tidy up your geometry a bit:
shell_01.3dm (5.2 MB)
Many thanks :slight_smile: I have already assumed that it has to do with the marked curves of you. How did you clean up? Which commands or which proceed did you use?
