Generate rectangle
I’ve tried to solve this problem but haven’t been able to… In Figure 1, there are two rectangles separated by a space… In Figure 2, that space is occupied by a green rectangle… I need to be able to generate that green rectangle automatically… I’ve tried without success; perhaps some extra data is missing, like a point x in that space… I had thought about using extend curve (Figures 3 and 4)…
You could almost vibe code your way through this. But… is this even coding/scripting related? You need to add tags to your post if you want concise help.
When you say automatically, how automatic are you hoping for?
Making some assumptions due to a lot of missing info, a 3 point rectangle is only three clicks in the viewport window. it’s going to be hard to beat that for efficiency.
If you can give some better context for what you are trying to do, people will be able to give far better assistance.
Use grasshopper?
