I’m frequently in a situation when I have to generate lots of simplified buildings on terrain models. I extracted the roof points from a LAZ file using CloudCompare and now I want to generate some simple solids using these points. Does someone have an idea how to best tackle this?
I projected the points to the ground and made a line from the roof to the ground. Is there a way to interpolate a solid using many curves or something? Like some kind of bounding box? The bottom face could be made flat and intersect with the ground (reconstructing points with lowest Z).
