I ran in some problems again…
So i am trying to write something to estimate the floorplan area of geometrie quickly
for that i would like to be able to load in multiple breps and then cut slabs and see in the end what i get…
unfortunatly i always have the areas that intersect between the breps as double area and with that a wrong result!?
Could anyone point me in the right direction?BGF test.gh (13.7 KB) Example GFA.3dm (317.7 KB)
You have two options with your file. Either you combine the three solids before creating the sections, or you shift the paths by -1 before creating the Region Union out of the curves. Hover your mouse on the inputs and outputs of each component to see the data structure or add a Param Viewer…
