Gene Inputs
“Genes are comprised from sliders or genepools.”
Is it possible to use other types of inputs or is the choice limited to these two components?
For example, I would like to use a graphmapper as a gen. How could I make this happen?
Greetings,
Ludwig
Maybe this can help.
Thanks!
Just in gereral:
Are there other panels that can be used as genomes in Wallacei besides slider and gene pools?
No. Genes that will connect to Wallacei should only be either Number Slider or Genepool objects. However you can do a lot with this and control the problem downstream creatively with sliders directly or indirectly
