GCON and Continuity
I created two curves in the Z and Y planes whose segments are all G1 or G2. I extruded and intersected to get the resulting curve. I exploded the curve and put alternate segments on different layer.
If I run GCON on the segments, all the joints are G1 or G2 except that the circled joints are out of tolerance.
Yet I can join all the segments together, even those out of tolerance.
Could this be correct?
Problem GCON.3dm.zip (14.1 KB)
Hello - there are very short curves in between the more obvious ones at these locations.
Thanks for pointing out what I missed.
