I have created a tool path and posted it to run on my machine and the gcode is showing it going in circles and not the actual path created. Any help would be appreciated. Thanks
How was the G-Code created? Not much info to go on here… Rhino does not have native toolpath programming nor g-code postprocessing.
–Mitch
As of now, there’s not a lot of information here to help out whatsoever.
What software did you use to create the gcode?
Which machine are you using?
How much experience do you have with creating gcode?
What settings did you use?
Which part are you trying to cut out?
Have you been running gcode created in the software you used now before on the machine? Did that go well?
Have you made gcode using a different software for your machine? Did that go well?
