GCode generated by Grasshopper to free print
I am trying to figure out how to do a cage strucure like this however i cant figure it out for the life of me to make a sensible repeating pattern. Pls help
Attach your file that contains you Brep
Grashopper heplp.gh (8.1 KB)
Sorry I forgot I meant to do that
Hi . I was busy so I couldn’t upload sooner . This is my approach for the first image :
Pattern_01.gh (17.7 KB)
Thank you very much!!!
Would you mind attaching your .gh file?
I attached now
For the second one :
( If you want to have every row separately , remove the gray group and connect the clean tree output directly to Multipipe )
Pattern_02.gh (25.6 KB)
Any slicing script is going to need the continuous printing path (curve) instead of a volume. Good job though. I am always impressed by how fast you are.
How can I pass the model to Gcode since the movements are moving on the Z axis
