I’m trying to animate a panel sliding through a rail by two wheels (4 wheels in two rails if you count both sides), similar to a garage door (sectional door).
How can I best approach this?
I currently have two points following the L-shaped curve. Now I’d like to somehow connect the panel to these two points.
Luc
(Luc Adriaenssen)
June 22, 2018, 7:19pm
2
I suggest you take a look at these 2 Forum-topics:
I have a theoretical question.
What would be the best approach when considering animating a train composition (lokomotive+wagons connected with spherical joint) that moves along a curve.
Should we place the lokomotive as parent of all the wagons, and create spherical hinge connection. But then how do we say to the wagons to also move along the curve.
Should we use inverse kinematics. But then the last wagon should be the grand-grand parent, and lokomotive should follow the point alon…
Hey, I am relatively new to Bongo, and i am trying to animate a shutter with several elements, following an curve. But there are 2 problems i can’t quite catch.
Picture 1)
[image]
Picture 2)
[image]
Picture 3)
[image]
As it can be seen in the attached pictures, the first element follows the path quite nicely until it reaches the horizontal part of the curve. There it instantly changes the orientation. I solved this once by turning the horizontal path before joining it to the curve, but…
Luc
