I am trying to optimize shells using Karamba and Galapagos. However, Rhino is always running into memory issues and giving the following error:
A memory allocation failed and Rhino will close.
Rhino attempted to save the current model on your Desktop in
RHINO_EMERGENCY_SAVE.3dm
This file may be damaged and should be used as a last resort.
Restart your computer.
This happens after a few hours of running the optimization. When the error message appears, I can only press OK and then Rhino shuts down and all optimization steps are lost.
Is the memory overflow (in my case, 64GB of RAM) a known issue, or is this a bug? Also, I am wondering why the memory is getting so full, when only parameters and results - in both cases only numbers - have to be saved.
It might help to reduce the number of saved iterations or limit the complexity of the optimization process in Galapagos. Also, check if your Rhino and Karamba versions are up to date, as newer updates often fix bugs.
Dear @cp1, I tested the newest Karamba version 3.1.5 - however the memory leak is still happening.
Optimization started with 9.6 GB RAM used, after about 4h is up to 27.4GB. Delta is 17.8GB and rising…
I am running 1 iteration per second
Rhino 8 SR15 2025-1-7 (Rhino 8, 8.15.25007.13001, Git hash:master @ 5eab31224f22c4e8793154a2c34faf8db6ab1d53)
License type: Educational Lab License, build 2025-01-07
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 9-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.39
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 9-13-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-10-2024
Driver Version: 32.0.15.5639
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Users\r.neumerkel\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Karamba3D\3.1.50121\net7.0-windows\Karamba3D_LicensePlugin_Rhino8.rhp "Karamba3DLicense"
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.15.25007.13001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.15.25007.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.15.25007.13001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.15.25007.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.15.25007.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 8.15.25007.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.15.25007.13001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
Additionally, I get very low CPU utilization when running the optimization… only 1-2 cores are working. Total CPU load when optimizing is at about 10%
