G1这两个插件中有大量便于出图的功能,是否考虑内置到G2中?
G1 has a lot of functions that are convenient for plotting. Is it considered to build them into G2?
另外:G2中的电池是否可以考虑像G1一样增加重命名功能?
In addition, can you consider adding renaming function to the batteries in G2 like G1?
G2中是否考虑内置下电池对其?类似SNAPPINGGECKO
Whether the built-in lower battery is considered in G2?
Hi -
There are a lot of functions in the two plug-ins of G1 that are convenient for drawing. Are you considering building them into G2?
In Rhino 8, a lot of features are being added to Grasshopper 1. See:
You can open Grasshopper 1 files in Grasshopper 2.
Also: Can the battery in the G2 consider adding a renaming function like the G1?
Could you explain what that means and how that would help you?
Is there a built-in battery in the G2? Similar to SNAPPING GECKO
What does that mean - please explain the need and not a reference to some plug-in.
Note that Grasshopper 2 is still in the very beginning of development. Specialized features will typically continue to have to be provided by 3rd party plug-ins.
1.我知道在G1中可是实现,但是希望未来在G2中也能实现。我发现在G2中引用G1的电池,有部分电池在文件保持二次启动后会出问题,不知道问题出在哪里,不知道是不是兼容性的问题。
2.重命名有助于我这种英文水平不好的快速检索电池,在G1中我通常会这么做。
3.这个插件的功能就是电池对齐,会让画图看起来更工整一些。
I know it can be achieved in G1, but I hope it can be achieved in G2 in the future. I found that G1 batteries are referenced in G2, and some batteries have problems after the file is kept for the second time. I don’t know what the problem is or whether it is a compatibility problem.
Renaming helps me to quickly retrieve batteries with poor English proficiency, as I usually do in G1.
The function of this plug-in is battery alignment, which will make the canvas look more neat.
