Do you need a surface (NURBS) strictly?
You should try to get your funnel shape to work as a single mesh, perhaps via a relaxation method using Kangaroo (many examples out there - or look at the kangaroo examples for grid shells).
One here
Another one here
One without kangaroo here
I bet these are not even the best ones.
Anyway, your result should be fairly close to the images you provide above as example/goal. Once you have that, you should be able to convert your mesh to clean quads and/or SubD. However conversion might not be necessary at all, for you can still get those trusses going by intersecting or projecting your lines on the mesh.
