Fun little typo/bug in Grasshopper
If there are exactly 3 instances of a cluster in a document, it says “This cluster occurs trice in this document” - it should be ‘thrice’.
You know what’s also fun? If you rename a component and then Undo, Undo reverts the name letter by letter. These aren’t really bugs.
This is a typo.
So you’d call this a feature?
True, I should have only said ‘typo’ and not used the word ‘bug’. You’re correct with that.
I can’t make any sense of how the undo-related observation is relevant here.
You should be able to edit your topic title…
This has been taken more seriously than intended. It was a lighthearted post about a typo.
