That’s better. But clicking on Fullscreen returns the same problem.
Hi @Gijs and @wim , i see that panel positions are now remembered once Rhino WIP is reopened, thanks !
Can repeat that here too, it messes up the default panel layout and the Main toolbar is restored to the right of the command history panel instead of below.
@Gijs can you repeat this (on a system using a comma as decimal seperator) and please create a bug item for it ?
thanks,
c.
Indeed, WIP fullscreen messes up panel positions harder than v7
I see that, but I don’t think this is related, since it happens independent from the regional settings.
RH-73631 Window Layouts fails to restore after Fullscreen
