Freestyle trimming of lines
In Autocad, there is a way to trim lines without specifying any reference cutting edges. I recorded a video for the same.
How can I do the same in Rhino?
Just select all the curves involved in your operation first and run Trim, you can pick whatever you want. CurveBoolean also helps with those particular examples.
Thanks! This worked really well! :pray:t3:I already knew about curve boolean but didn’t know about selecting all the curves to get the freestyle trimming done.
