Hi @karamba3d,
Is it possible to connect a free shaped beam with changing cross section to Karamba3D?
Is it possible to connect something like a brep to Karamba3D?
Hi @karamba3d,
If you want to set different cross sections you can split up the beam into smaller segments. However Karamba3D will not be able to calculate a true trapered or changing cross section. You can refer to Single Span Beam – Karamba3D
It is not possible to analyse breps as a beam in Karamba3D.
