Hello all,
I have a rather more specific question regarding stairs. The application for designing stairs is great! But I would like to model an existing staircase with special properties.
Is there a Grasshoppers file with the following properties?
Red line = Set boundary
Green line = Each single step or reference line is freely selectable
Yes, I could also remodel the stair using Rhino tools + create a 2D drawing. Then create a block, insert point etc = done!
But I want to keep the parametric properties (BIM), so that when I export it to Revit or ArchiCAD the specific properties are preserved.
I imagine it like this. There is a GH file where I can assign the curves and enter different parameters for the heights, slab thickness etc…
Is this possible?
Many greetings
Boris
Translated with DeepL Translate: The world's most accurate translator (free version)
