I accidentally stumble on a mysterious command ‘FP’. When running, the prompt ask me ‘Select a patch to fit:’.
It also won’t appear in the CommandList, and is not a defined alias.
Do someone know what is this command for? I didn’t manage to find documentation on it.
Thanks!
wim
(Wim Dekeyser)
July 23, 2020, 8:23am
2
Hi - I see that was present in Rhino 5 as well. Probably just an old test command that accidentally didn’t get hidden well enough. I’ll get someone to look into that - RH-59605 .
Thanks,
wim
(Wim Dekeyser)
July 23, 2020, 11:38am
4
kleerkoat:
what does it do?
You tell me…
It seems to create a new surface and points when you select a sub-surface in a polysurface.
i can’t get it to do anything, what am i supposed to select? i made a patch but i can’t select it.
wim
(Wim Dekeyser)
July 23, 2020, 12:25pm
6
I’m utterly confused as to why you would spend energy trying to get an old test command to do anything useful at all…
-w
