If you’re still on Rhino 7 for Mac, you’re not alone. I haven’t upgraded either.
I’m an architect, and I’ve been building Forsk, a Rhino plugin for students, freelancers and small firms designing homes. It takes you from a plan image to a drawing set, inside your own Rhino file.
Most CAD and AI tools are built for large offices and commercial projects. Forsk is built for residential work, and I want to keep it affordable and updated often.
What it does**
- Turns a vector PDF, DXF, scan or photo of a plan into walls, doors, windows and rooms at true size
- Lets you edit by clicking in Rhino or by asking in the chat
- Furnishes a room or the whole house with 43 residential pieces
- Gives floor areas and a first-pass daylight estimate for every room, updating live as you edit
- Prints plans, facades, sections and schedules on A4 to A1 sheets with your own title block
- Exports to vector PDF, DWG/DXF and IFC
Install
In Rhino 7 for Mac, type PackageManager, search for Forsk and click Install. Full setup steps are here:
Food4Rhino.com/Forsk
Free for early testers
This is an early version, so I’m releasing it quietly and looking for testers. Rhino 7 users get a free licence.
Rhino 8 and Windows
I know most of you are on Rhino 8. The Rhino 8 for Mac version is already in progress and should be out in about two weeks. The special offer goes out by email to waitlist members only, so if you’re on Rhino 8 for Mac, sign up now so you don’t miss it: forsk.app/waitlist
Windows is a different story. I build on a Mac, so supporting Windows means buying a Windows machine first. I’ll do that once the waitlist reaches 100 Windows signups. If you want Forsk on Windows, the waitlist is the way to make it happen.
If you try it, I’d really like to hear what breaks and what’s missing. Share issues and ideas in this thread, or send your bug report directly from the Forsk chat window.
Small update: 1.5.0 is out today. Check the plan now reads each line as you draw it, handles double and sliding doors, lets you set the scale at any time, and Forsk follows Rhino’s dark mode.
New versions come out almost daily, and you can follow along here:
Forsk v1.7.0 is out. See release notes
Introducing Add plan image, a faster way to turn a floor plan image into a 3D model of a floor.
Click “Add plan image” and place your plan. First set the opacity so you can see it clearly, then scale it by picking two points and typing the real length between them. After that, trace freely with the normal tools. Walls, doors, windows and stairs are 3D as you draw them, so the 3D model is ready when you finish tracing. You can show or hide the image at any time and change its opacity in 10% steps.
Other changes in this version:
- Opening Forsk now gives you a focused plan view, with Rhino’s side panel hidden and a single Top viewport.
- DXF and DWG files open straight into Generate 3D.
- Renders are flatter and clearer, and the roof is always visible.
- One Undo now takes back exactly one change.
Tracing several floors on top of each other isn’t solved yet. I’m looking at a more precise scaling step that uses anchor points from the floors you’ve already traced. It will need some testing before I get it right, so suggestions are welcome.
The goal with Forsk is always to speed up project delivery. I’m on a mission to save architects precious hours and give you a competitive edge.
Forsk 1.8.5 is out! See What’s new
This update brings back detection capabilities for openings (windows and doors). Detection for walls is not supported. The workflow is now to scale the floor plan image, draw the walls, and let AI detect all the openings.
Setting wall types is now much easier than before, there are clear wall types, and each type has several thickness options, so you can quickly find the right wall type and thickness for your project.
Ability to add columns both rectangular and circular is added. You can also create areas wihtout the need for wall geometry, which is handy for balcony, terrace, ect. Drawing stairs is much easier now, Forsk now supports 90-degree angled stairways.
