Forcing Rhino to Load a Language Template
Hi all,
I have two questions about schemes in Rhino 3d.
  1. How is it possible to force Rhino to load the 2004 polyline scheme and in every language?
  2. I am develloping a pluging in Rhino with Vb6.
    If the user an another language than the English version my plugin doesn’t work anymore.
    I tried to find why and the response is based on the
    Rhino.Command(“MyEnglishCommand”) . MyEnglishCommand is unrecognized because the template loaded in Rhino is different. How can I solve this problem?
Hi @Markus_Erhardt,
What version of Rhino? Why do you need to do this?
Vb6 or Visual Basic .NET?
– Dale
With vb6.
I found the solution. I can give the answer if you want. It 's all about registers
