Force a command line parameter to a value
Hello Forum,
I’d like to force the “distance” parameter in the “offset” command-line command to a specific value. Is there a way to do it? I’m working under RhinoCommon
Thanks. L
How about this?
RhinoApp.RunScript("_Offset _Distance=3.0 ...
You can also just use Rhino.Geometry.Curve.Offset.
http://developer.rhino3d.com/api/RhinoCommonWin/html/Overload_Rhino_Geometry_Curve_Offset.htm
– Dale
Dale,
thanks.
I’ve been to short in the problem description and sadly in my specific case both of your advises do not solve it.
I have to operate on the command line and set the offset to a fixed value. In the same time I don’t want the user to be able to modify it.
In other words what I need is a custom command-line command where the _Distance parameter is not listed or is set read only. Is it feasible?
Thanks. L
Sorry no. The only way of doing this is to write your own Offset command…
Dale,
not even feasible to force a range for that parameter?
Thanks. L
Basically, a plug-in cannot change the behavior of an existing command.
If you want a version of the Offset command that limits the distance to some range, then you’ll need to provide your own command.
Does this help?
– Dale
Dale,
Thanks. L
