For a local Art manifestation, Pictures only in Rhino 7 and Camtasia
Unfortuately this can not be done in Rhino 8 so I do not upgrade until the “Problem” is solved
what part can’t be done?
what “problem” are you referring to?
I assure you that you can in fact texture map three spheres and the background, use the turntable command, and screen record the result in Rhino 8.
Hi JSB.Walker
show me,
herewith the pictures I used
Can you make the same animation?
I don’t think so, You have no idea how I do this.
Have a nice evening
Karel
(attachments)
In Rhino 7
I do all my work in Wireframe even animation Herewith, and can clearly see what I am doing with my pictures.
In Rhino 8 I immediately lose control because I have to work in Render field to see results.
have you seen the animation?
I am able to make the text visible from all angles.
Not possible in Rhino 8, I have only the no saving version.
If you say it can be done anyway, show me.
Karel
(attachments)
you can 100% texture map 3 spheres and do a turntable animation in v8. It takes like 5 seconds to set it up.
exactly the same way you can do it in v7.
you can use a background bitmap instead of an environment as your backdrop if you don’t want the background to rotate with the object. Or adjust the lighting, or the mapping (so you don’t have visible seams like your does) or any other parameter you need.
I used the windows snipping app to screen record this- start to finish took less than 3 min.
here it is without a rotating background.
