Footwear outsole help
Hi everyone, im a industrial designer student, im learning 3d footwear in rhino by myself, i just want to ask you, how can i model this part of the outsole?? I tried a lot of things but never find the perfect command for everyshoes! Ive tried with crv2views and adjust the outsole srf with command points, project in to the upper, join the outsole with the curve projected, idk what can i do for make that part good!
There are so many possibilities to create that, but what I personally find easiest is this method:
Ty! But im not sure thats can solve my problem, my problem is only to creat the front part of the outsole!
The part who “touch” the upper in the front part, or maybe if u know other method!
I don’t understand what you mean “touch” , if you look at my method, you will see that I explained the bending of front of sole very clearly, the pieces that this sole hanging together material is then easy to create a surface via their edge lines.If that’s what you mean.
