How can I make it that food4Rhino opens my plugin in Rhino 7 where it is targeted at?
It’s this one that gives the issue: Global Edge Continuity (beta) | Food4Rhino
I have same issue. I think link to package manager from food4rhino is using highest Rhino version. Including WIP.
I have assumed each individual with wip installed will know what to do.
It would be good to have option to choose which version shall be executed.
I see, but in your case you do have a build for V8, in my case I don’t and it is still targeting the WIP.
Can you share a screenshot of the message that the browser shows? What happens if you click “Allow” when it asks to open in Rhino WIP?
I get to see this:
So I click on open and then WIP opens with the packagemanager open and I get this:
This is the command history:
Handling url: rhino://package/search?name=stgGlobalEdgeContinuity
Command: _-PackageManager
Choose option ( Search ): _Search
Search term: stgGlobalEdgeContinuity
I have seen same mesages before my plugin was published for WIP.
Sorry, I misunderstood. The Food4Rhino team are discussing how to handle this situation better.
At the moment F4R has no way of knowing what the user will have installed on their machine. We use a protocol handler that will effectively run in the last Rhino version you installed, hence why some of you are seeing this pop up in the WIP. I think we have a few ideas on making this a bit better thanks to some tips from @will
