Font Family not shown in Rhino 8 for Mac
I´m using Rhino 8 for Mac and I installed a free Google font on my Mac.
Rhino only shows one Typestyle (Regular or Medium) and not the whole font family.
Also when i print the Layouts with the built in pdf - printer (Rhino) the fonts get substituted with another font.
is there any reason the font is not shown completely? (fontformat is ttf) Other apps like Indesign show the whole font family.
Hi Josef, that’s most likely a variable font. Google Fonts’ default download is a single variable TTF that stores the weights inside the file, and Rhino only shows the default one, so you get a single typestyle.
Try this: in the zip you downloaded from Google Fonts, open the static folder — it has a separate TTF for each weight (Light, Regular, Medium, Bold, …). Install those instead of the variable file and the full range should appear in Rhino, which will likely sort out the PDF substitution as well.
Hi Japhy, i already did this but only the regular typestyle is shown - in the font i chose the number 4 is also not shown correctly in the app. when i print its shown correct.
Thanks Josef — that rules out my first guess. Two separate bugs here, both reproduced on Rhino 8.35 / macOS.
The missing weights: Rhino only supports four faces per family — Regular, Bold, Italic, Bold Italic. Plus Jakarta Sans has eight, so the rest have nowhere to go. With the static files, Light and Medium both land in the Regular slot and Medium wins, which is what you’re seeing. Filed as RH-99544.
The broken 4: specific to the variable font. With the variable PlusJakartaSans[wght].ttf installed the 4 fills in exactly as in your screenshot; with only the static TTFs it draws correctly. Printing is fine because it uses a different text path. Filed as RH-99545.
Fix for now: delete the variable version from Font Book and keep only the static files. That sorts out the 4. You’ll still be limited to Regular and Bold until RH-99544 is addressed.
OK - The Text above was written with the .ttf file format - so the “4 bug” is also from the truetype font.
some fonts seem to work in different typestyles - for example Hiragino Sans W0 till W9
or Ping Fang SC:
i found out, that the file directory of the fonts is different - the direction is chosen automatically when a font gets installed - is there any difference which directory rhino is choosing?
The install directory makes no difference — Rhino asks macOS for the installed fonts regardless of where they live. What matters is how the font file names its family.
Dan, who i would typically direct the mac font questions to is out this week.
from what i can gather..
Google’s default download is the variable file (PlusJakartaSans[wght].ttf), that’s a .ttf as well. The individual weights are in the static folder of that same zip. With only the static Regular installed here the 4 draws correct, with the variable installed it fills in.
Hiragino Sans W0-W9 are ten separate font families, not one family with ten styles. That’s why they all show up.
