This only happens after I upgrade to R6.
text and text portion of the dimension sometime will not render in view, will come back if I force some kind of “redraw” by copy>delete>paste, or change the dimension style tied to the text globally, I’m only seeing this when I’m using the font KievitOT family.
Noticed bug-like behavior below:
will sometime disapear
will sometime crash R6 when trying to edit text (crash report sent)
if I’m using KievitOT-black for example for a dimension style on a text, whenever I try to edit the text, the font for that specific text object will revert to a KievitOT-regular, and will only come back to normal if I do a global change to that dimension style
Is this a compatibility issue with this specific font, or a type of fonts, or do you think I have a corrupted font file? The font is installed by my companies’ IT all on laptop so it shouldn’t be the issue I think.
Hi Jun - thanks, I made an annotation style with these - I’ll see how they behave here. @Jun_Wang - does the bad stuff happen in layouts or model space or both?
Hi Jun - can you try SR12? To do this, change Options > Updates and Statistics > Update frequency to ‘Service release candidate’ and then check for updates.
