Hi, I’m very new to Grasshopper and was trying to use the Follow Path Force command in Quelea and got the error “Solution Exception: Object reference not set to an instance of an object”. Any idea what this means or how to solve it? File attached below! path error.gh (14.3 KB)
Usually means the code is not getting the object it needs (Either by user or some flaw in the code), potentially something is returning null. Impossible to tell without a file and screenshots.
Hi, thanks for the quick reply - I’ve attached the file to my original post!
Hi, even I am facing the same issue, did you find any solution for it?
